Saltar al contenido principal
Acer Chromebook C710-2833 Speakers Replacement
Qué necesitas
  1. Acer Chromebook C710-2833 Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Speakers Replacement: paso 2, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the 6 mm Phillips #00 screw that holds the back cover on.
    • Carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Speakers Replacement: paso 3, imagen 1 de 1
    • Using the spudger or your finger, slide the battery release slider and hold in place as shown.
    • When reassembling, holding of the slider is not needed.
  4. Acer Chromebook C710-2833 Speakers Replacement: paso 4, imagen 1 de 1
    • While holding the slider, pull out the old battery.
  5. Acer Chromebook C710-2833 Speakers Replacement: paso 5, imagen 1 de 3 Acer Chromebook C710-2833 Speakers Replacement: paso 5, imagen 2 de 3 Acer Chromebook C710-2833 Speakers Replacement: paso 5, imagen 3 de 3
    • Remove the two 3 mm Phillips #00 screws located on the WiFi card.
    • Pop the wires off the WiFi card.
    • Tilt the WiFi card up and remove it by pulling.
  6. Acer Chromebook C710-2833 Speakers Replacement: paso 6, imagen 1 de 1
    • Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
    • Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
  7. Acer Chromebook C710-2833 Speakers Replacement: paso 7, imagen 1 de 3 Acer Chromebook C710-2833 Speakers Replacement: paso 7, imagen 2 de 3 Acer Chromebook C710-2833 Speakers Replacement: paso 7, imagen 3 de 3
    • Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
    • Gently pull the ribbon cable out.
    • Remove the Solid State Drive.
  8. Acer Chromebook C710-2833 Speakers Replacement: paso 8, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
    • Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
  9. Acer Chromebook C710-2833 Speakers Replacement: paso 9, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 9, imagen 2 de 2
    • Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
    • Pry apart the back casing from the keyboard housing.
  10. Acer Chromebook C710-2833 Speakers Replacement: paso 10, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 10, imagen 2 de 2
    • Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
    • Use the angled tweezers to gently remove the ribbon cable.
  11. Acer Chromebook C710-2833 Speakers Replacement: paso 11, imagen 1 de 1
    • Lift the keyboard off of the back casing.
  12. Acer Chromebook C710-2833 Speakers Replacement: paso 12, imagen 1 de 1
    • Remove the four 3 mm Phillips #00 speaker screws.
    • Note that these screws have an especially large diameter head.
  13. Acer Chromebook C710-2833 Speakers Replacement: paso 13, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 13, imagen 2 de 2
    • Using the opening tool, gently pull out the connector that connects the left speaker to the motherboard.
    • Lift, but do not completely remove the speakers. They are still attached by wire.
  14. Acer Chromebook C710-2833 Speakers Replacement: paso 14, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 14, imagen 2 de 2
    • Using the opening tool, gently pull the two connector flanges holding the large ribbon cable.
    • Gently pull the large ribbon cable to disconnect it.
  15. Acer Chromebook C710-2833 Speakers Replacement: paso 15, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 15, imagen 2 de 2
    • Use an opening tool to remove the head of the last connected ribbon cable.
    • With your hand, grasp the pull tab and disconnect the ribbon cable.
  16. Acer Chromebook C710-2833 Speakers Replacement: paso 16, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 16, imagen 2 de 2
    • Using the opening tool, gently pull the connector flange connecting the small wires.
    • Gently pull the black connector from the cream-colored connector to disconnect the wires.
  17. Acer Chromebook C710-2833 Speakers Replacement: paso 17, imagen 1 de 1
    • Remove the 3mm #00 Phillips screw near the bottom of the blue board.
  18. Acer Chromebook C710-2833 Speakers Replacement: paso 18, imagen 1 de 3 Acer Chromebook C710-2833 Speakers Replacement: paso 18, imagen 2 de 3 Acer Chromebook C710-2833 Speakers Replacement: paso 18, imagen 3 de 3
    • Using the opening tool, gently pry the main circuit board out of the casing.
    • Gently tilt the main circuit board up.
    • Place the circuit board to the side.
    • The circuit board is still connected at the hinge top left, do not attempt to remove it.
  19. Acer Chromebook C710-2833 Speakers Replacement: paso 19, imagen 1 de 2 Acer Chromebook C710-2833 Speakers Replacement: paso 19, imagen 2 de 2
    • Remove the black tape over the wire, holding it in.
    • Remove the wire from under the hooks keeping it in place.
    • The speakers and wires are now ready to be removed, and new ones installed.
Conclusión
Ethan DeRuby
Miembro Desde 09/24/17
298 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G6, Harley Fall 2018 Miembro de IUPUI, Team S1-G6, Harley Fall 2018
IUPUI-HARLEY-F18S1G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 613
