Saltar al contenido principal
Acer Chromebook C710-2833 Hard Drive Replacement
Qué necesitas
  1. Acer Chromebook C710-2833 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Chromebook C710-2833 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 Hard Drive Replacement: paso 3, imagen 1 de 2 Acer Chromebook C710-2833 Hard Drive Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Locate the hard drive.
    • Locate the four 3 mm Phillips #00 screws on each corner of the hard drive.
    • Take your driver with the PH00 bit attached and unscrew all four screws.
    • Place the screws off to the side for now.
  5. Acer Chromebook C710-2833 Hard Drive Replacement: paso 5, imagen 1 de 2 Acer Chromebook C710-2833 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Once all the screws are out, gently pull the hard drive out as pictured.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G6, Nance Fall 2017 Miembro de USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,202
