Saltar al contenido principal
Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
Qué necesitas
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 2, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 2, imagen 2 de 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 3, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 4, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 4, imagen 2 de 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: paso 5, imagen 1 de 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: paso 5, imagen 2 de 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: paso 5, imagen 3 de 3
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 6, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: paso 6, imagen 2 de 2
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
Conclusión
5 personas más completaron esta guía.
Sakiynah Howard
Miembro Desde 10/17/17
1,000 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 Miembro de UMass Dartmouth, Team S1-G3, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G3
Miembros de 3
12 Guías creadas
Un comentario
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 3,586
