Saltar al contenido principal
Acer Chromebook 15 CB5-571-C09S Battery Replacement
Qué necesitas
  1. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 2, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 2, imagen 2 de 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 3, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 4, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 4, imagen 2 de 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: paso 5, imagen 1 de 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: paso 5, imagen 2 de 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: paso 5, imagen 3 de 3
    • The battery is the large black rectangle located in the bottom center of the device.
    • Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
  6. Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 6, imagen 1 de 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 6, imagen 2 de 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery connector from the motherboard using two plastic opening tools.
    • The battery connector is the white "plug" that connects the battery to the motherboard with rainbow colored wires attached to it.
    • Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
  7. Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 7, imagen 1 de 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: paso 7, imagen 2 de 2
    • Once the battery has been disconnected from the motherboard it can easily be removed from the device.
    • Grab the top edge of the battery and carefully pull it up and out of the device towards you.
Conclusión
8 personas más completaron esta guía.
Sakiynah Howard
Miembro Desde 10/17/17
1,000 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 Miembro de UMass Dartmouth, Team S1-G3, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G3
Miembros de 3
12 Guías creadas
2 comentarios
Where do you get the plastic opening tools
Kelly Robledo - Contestar
Instructions were perfect. Used a putty knife to pry off the back
Naomi Harrison - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 4,204
