Saltar al contenido principal
Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement
Qué necesitas
  1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 1 de 1
    • Place the device on a flat surface with the bottom facing upwards.
  2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
  3. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 3, imagen 1 de 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
    • Be careful not to damage or crack the back cover of the device.
  4. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Carefully remove the back cover.
  5. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 5, imagen 1 de 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 5, imagen 2 de 2
    • Locate the Wi-Fi card. It will be white chip beside the motherboard.
    • Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
  6. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 6, imagen 1 de 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 6, imagen 2 de 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: paso 6, imagen 3 de 3
    • Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
    • Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
    • Have your new replacement Wi-Fi card ready to place back in the slot.
Conclusión
Avinesh Mohanaranjan
Miembro Desde 09/16/21
183 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 39
Todo El Tiempo: 740
