Saltar al contenido principal
Acer Chromebook 15 C910-C453 Trackpad Replacement
Qué necesitas
  1. Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: paso 1, imagen 1 de 2 Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 3, imagen 1 de 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 3, imagen 2 de 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 4, imagen 1 de 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 4, imagen 2 de 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 5, imagen 1 de 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: paso 6, imagen 1 de 2 Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: paso 6, imagen 2 de 2
    • Unscrew the seven 6mm Phillips screws located around the trackpad.
  7. Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 7, imagen 1 de 1
    • Lift up the rectangular metal plate at the base.
  8. Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 8, imagen 1 de 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 8, imagen 2 de 2
    • Flip the black bar where the white ribbon is connected to the trackpad upward to unlock it.
    • Gently pull the white ribbon away from the trackpad.
  9. Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 9, imagen 1 de 2 Acer Chromebook 15 C910-C453 Trackpad Replacement: paso 9, imagen 2 de 2
    • Gently lift the trackpad up and pull towards you to remove the trackpad.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S15-G1, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 409
