Saltar al contenido principal
Acer Chromebook 15 C910-C453 Solid-State Drive Replacement
Qué necesitas
  1. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: paso 1, imagen 1 de 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: paso 3, imagen 1 de 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: paso 3, imagen 2 de 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: paso 4, imagen 1 de 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: paso 4, imagen 2 de 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: paso 5, imagen 1 de 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: paso 6, imagen 1 de 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: paso 6, imagen 2 de 2
    • Remove the screw at the left of the drive.
  7. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: paso 7, imagen 1 de 1
    • Remove the drive by pulling it gently to the left.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team S15-G1, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 58
Todo El Tiempo: 5,709
