Saltar al contenido principal
Acer Chromebook 15 C910-C453 Fan Replacement
Qué necesitas
  1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: paso 1, imagen 1 de 2 Acer Chromebook 15 C910-C453 Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Fan Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Fan Replacement: paso 3, imagen 1 de 2 Acer Chromebook 15 C910-C453 Fan Replacement: paso 3, imagen 2 de 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Fan Replacement: paso 4, imagen 1 de 2 Acer Chromebook 15 C910-C453 Fan Replacement: paso 4, imagen 2 de 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Fan Replacement: paso 5, imagen 1 de 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Fan Replacement, Fan: paso 6, imagen 1 de 1
    • Unscrew the following Phillips #1 screws:
    • Two black 4mm Phillips screws located on the fan.
    • Four copper 4mm Phillips screws located on the heat sink.
  7. Acer Chromebook 15 C910-C453 Fan Replacement: paso 7, imagen 1 de 1
    • Disconnect the fan from the motherboard by pulling down on the wire connector with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Fan Replacement: paso 8, imagen 1 de 1
    • Lift up the fan while unwrapping the black and white wires from around the fan.
    • Do not pull wires off of the motherboard.
    • Remove the fan.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S15-G1, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 491
