Saltar al contenido principal
Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement
Qué necesitas
  1. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: paso 1, imagen 2 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: paso 1, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 2, imagen 1 de 2 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the screen brackets.
    • Use tweezers to set aside the ground tape (tan) and the electrical tape (black). This may need to be reconnected during reassembly.
  3. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 3, imagen 1 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 3, imagen 2 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 3, imagen 3 de 3
    • Use tweezers to detach the webcam connectors from the motherboard.
    • Keep in mind that the black cable connects to the left pin and the white cable connects to the right pin.
    • There may be electric tape covering the connectors. Use tweezers to set aside the tape for reuse.
  4. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 4, imagen 1 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 4, imagen 2 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 4, imagen 3 de 3
    • Disconnect the display panel connector from the motherboard. The connector should slide out away from the motherboard.
    • Be sure to remove the connector evenly from the port.
  5. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 5, imagen 1 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 5, imagen 2 de 3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: paso 5, imagen 3 de 3
    • To remove the lid from the laptop, pivot each end on the hinge and lift the rest of the laptop up and away from the lid.
    • Remove the display assembly from the laptop case.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 813
