Saltar al contenido principal
Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement
Qué necesitas
  1. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: paso 3, imagen 1 de 2 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: paso 3, imagen 2 de 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: paso 4, imagen 1 de 1
    • Lift off the back cover.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 678
