Saltar al contenido principal
Acer Chromebook 13 CB5-311-T7NN Battery Replacement
Qué necesitas
  1. Acer Chromebook 13 CB5-311-T7NN Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: paso 2, imagen 1 de 1
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: paso 3, imagen 1 de 1
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: paso 4, imagen 1 de 1
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: paso 5, imagen 1 de 2 Acer Chromebook 13 CB5-311-T7NN Battery Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 33
Todo El Tiempo: 1,436
