Saltar al contenido principal
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
Qué necesitas
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: paso 1, imagen 1 de 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: paso 1, imagen 2 de 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: paso 3, imagen 1 de 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: paso 4, imagen 1 de 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: paso 4, imagen 2 de 2
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: paso 5, imagen 1 de 1
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: paso 6, imagen 1 de 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: paso 6, imagen 2 de 2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: paso 7, imagen 1 de 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: paso 7, imagen 2 de 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: paso 7, imagen 3 de 3
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
Conclusión
Equipo
USF Tampa, Team S15-G4, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 178
