Saltar al contenido principal
Acer Aspire V5-591G-75KE Power Jack Harness Replacement
Qué necesitas
  1. Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Acer Aspire V5-591G-75KE Disassembly: paso 1, imagen 1 de 3 Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Acer Aspire V5-591G-75KE Disassembly: paso 1, imagen 2 de 3 Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Acer Aspire V5-591G-75KE Disassembly: paso 1, imagen 3 de 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 2, imagen 1 de 2 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 2, imagen 2 de 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 3, imagen 1 de 2 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 3, imagen 2 de 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 4, imagen 1 de 3 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 4, imagen 2 de 3 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Power Jack Harness: paso 5, imagen 1 de 2 Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Power Jack Harness: paso 5, imagen 2 de 2
    • Locate the power jack harness on the upper left quadrant of your device.
    • Note where the power jack harness connects to the mother board of your device.
  6. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 6, imagen 1 de 1
    • With a pair of blunt tweezers, push on the side tabs of the connector to disconnect the harness from the motherboard.
  7. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 7, imagen 1 de 3 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 7, imagen 2 de 3 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 7, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the single 10mm Phillips Head screw located on the hinge.
    • Wedge the spudger tool below the hinge, and lift only enough to get a grip with your fingers.
    • Use your hand to lift the hinge the rest of the way to avoid damaging your spudger tool.
  8. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 8, imagen 1 de 2 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 8, imagen 2 de 2
    • Wedge the spudger tool below the port harness head, and lift straight up until the side tabs clear the channels on each side.
    • There is a piece of tape holding the power jack harness in place, which will give you some resistance. Prying through this tape will not damage the harness.
  9. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: paso 9, imagen 1 de 1
    • Lift to completely remove the rest of the power jack harness out of the casing.
Conclusión
Una persona más ha completado esta guía.
Reina Godeck
Miembro Desde 10/16/17
741 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team S3-G5, Liner Fall 2017 Miembro de UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
Miembros de 4
18 Guías creadas
3Guía Comentarios
Thank you so much! Just fixed my finance’s computer using these directions and I’m a hero!
Amanda M. - Contestar
Okay, so I did fix this… But after we booted up the sound stopped working. I was very careful, but maybe knocked something? Any suggestions much appreciated.
Thank you
Check the step where you open the case. There is a cable you need to remove thats holding the case to the laptop. Just link that back to where it was and it should work
hrstg -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,617
