Introducción
This guide will help you identify, remove, and potentially replace the memory modules within the Acer Aspire V5-591G-75KE.
Acer Aspire V5-591G-75KE is manufactured with two DDR4 SDRAM memory card slots with a standard capacity of 16 GB and a maximum of 32 GB.
Qué necesitas
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
Using both hands, pull the clasps away simultaneously in order to release the memory modules.
