Qué necesitas
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Herramienta utilizada en este paso:Tweezers$4.99
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
Una persona más ha completado esta guía.
1Guía Comentario
Buna ziua , Se poate înlocui procesorul cu unul m-ai performant (Gen I9,I7 -14700 ,etc.) ? Care ar fi acesta ?Mulțumesc !
