Introducción
This guide will show you how to replace the display assembly of the Acer V5-571-6889 laptop. The display assembly will need to be replaced if the laptop screen is cracked, damaged, or just not working properly. Some common problems include a flickering laptop screen or completely blank screen.
Before getting to work replacing the display assembly, it is important to make sure that the display assembly is the cause of the problem. A laptop screen will also be completely blank if there is a power failure causing the laptop to not turn on. To verify this is not the cause, try to listen for a whirring sound, meaning the hard drive is spinning. Also, check to see if any other lights on the laptop are lit. For more information on troubleshooting, this link provides a detailed guide:
It is important to note that the replacement of the display assembly is moderately difficult. To ensure no damage is sustained, carefully disconnect cables and verify that the power is off before beginning.
Qué necesitas
Flip laptop over so that the back is facing upward.
Push switch to the right.
Pull battery away from the laptop.
Disconnect the two ribbon cables at the near left.
Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
Use a prying tool to remove the upper cover.
Remove the top left screw that is connecting the display assembly and the body of the laptop.
Remove the 2.5 mm by 5 mm screw by using #0 Phillips head screw driver.
Una persona más ha completado esta guía.
