Saltar al contenido principal
Acer Aspire V5-131-2680 Screen Replacement
Qué necesitas
  1. Acer Aspire V5-131-2680 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Open up your laptop.
    • Place an opening tool in the crack between the screen and the back compartment. Drag the opening tool throughout the crack to open.
    • Remove the front black frame of the laptop.
  2. Acer Aspire V5-131-2680 Screen Replacement: paso 2, imagen 1 de 1
    • Use a JIS #1 screwdriver to remove the 10 marked M2 x 3 Phillips screws.
    • Use a magnetic bit to fully remove the screws from their locations.
  3. Acer Aspire V5-131-2680 Screen Replacement: paso 3, imagen 1 de 1
    • Remove then aluminum frame holding the screen in place.
    • This frame may have some sharp edges. Lift and remove slowly.
  4. Acer Aspire V5-131-2680 Screen Replacement: paso 4, imagen 1 de 1
    • Carefully peel off the tape surrounding the screen.
  5. Acer Aspire V5-131-2680 Screen Replacement: paso 5, imagen 1 de 1
    • Unplug the pin conector from the display.
    • This is a sensitive piece. Do not grab harshly or the pin can break.
    • The screen is now free to be removed.
Conclusión
Mauricio Moreno
Miembro Desde 09/26/22
601 Reputación
5 Guías creadas
Equipo
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 151
