Saltar al contenido principal
Acer Aspire V5-131-2680 Hard Drive Replacement
  1. Acer Aspire V5-131-2680 Hard Drive Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire V5-131-2680 Hard Drive Replacement: paso 2, imagen 2 de 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • On the sides of the hard drive, you will see two side tabs. This is what holds the hard drive in place.
    • Place your finger on the left tab and press on it to loosen the hard drive.
    • After the hard drive is loose, slide it out of the compartment.
    • Do not remove your finger from the side tab while removing the hard drive.
  4. Acer Aspire V5-131-2680 Hard Drive Replacement: paso 4, imagen 1 de 1
    • You have successfully removed the hard drive from the laptop.
Conclusión
Mauricio Moreno
Miembro Desde 09/26/22
601 Reputación
5 Guías creadas
Equipo
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 212
