Saltar al contenido principal
Acer Aspire V5-131-2680 Battery Replacement
Qué necesitas
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: paso 2, imagen 1 de 2 Acer Aspire V5-131-2680 Battery Replacement: paso 2, imagen 2 de 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: paso 3, imagen 1 de 2 Acer Aspire V5-131-2680 Battery Replacement: paso 3, imagen 2 de 2
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
Conclusión
Naomi Zaldana
Miembro Desde 09/26/22
147 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 220
