Introducción
If the screen on your Acer Aspire V5-232-2629 laptop is cracked or completely black, the screen will likely require replacement. This 11-step guide will give you detailed instructions for replacing the screen.
A properly functioning laptop screen should have a high-resolution display and be free of cracks or any other visible damage.
Before replacing the screen, it is important to first power off and unplug your laptop. While on step 9, be careful not to damage the cables which run between the tape and the screen.
No special skills are needed to replace the screen.
Qué necesitas
Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
Remove the single Phillips #0 screw from the cover on the underside of the laptop.
Remove the screen bezel by lifting up the inside rim of the bezel and popping the edge out in steady upwards and outwards motions.
Complete this motion around the entire circumference of the bezel.
