Introducción
If your wireless connection is inconsistent or unresponsive the network card may be faulty. Use this guide to replace the network card and get back online.
Qué necesitas
Remove the nine 4mm screws with a PH0 screwdriver.
Remove the two 6mm screws with a PH0 screwdriver.
Remove the wire connector from the network card using a plastic opening tool.
Casi Terminas!
Conclusión
