Saltar al contenido principal
Acer Aspire V5-122P-0468 Battery Replacement
Qué necesitas
  1. Acer Aspire V5-122P-0468 Battery Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire V5-122P-0468 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Battery Replacement: paso 2, imagen 1 de 2 Acer Aspire V5-122P-0468 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Battery Replacement: paso 3, imagen 1 de 2 Acer Aspire V5-122P-0468 Battery Replacement: paso 3, imagen 2 de 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Battery Replacement: paso 4, imagen 1 de 3 Acer Aspire V5-122P-0468 Battery Replacement: paso 4, imagen 2 de 3 Acer Aspire V5-122P-0468 Battery Replacement: paso 4, imagen 3 de 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Battery Replacement: paso 5, imagen 1 de 3 Acer Aspire V5-122P-0468 Battery Replacement: paso 5, imagen 2 de 3 Acer Aspire V5-122P-0468 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
Conclusión
4 personas más completaron esta guía.
Nat McCormick
Miembro Desde 02/15/18
801 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S16-G1, Boczar Spring 2018 Miembro de USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 10,704
