Saltar al contenido principal
Acer Aspire V3-771G Hard Drive Replacement
Qué necesitas
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: paso 2, imagen 1 de 3 Acer Aspire V3-771G Hard Drive Replacement: paso 2, imagen 2 de 3 Acer Aspire V3-771G Hard Drive Replacement: paso 2, imagen 3 de 3
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: paso 3, imagen 1 de 2 Acer Aspire V3-771G Hard Drive Replacement: paso 3, imagen 2 de 2
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: paso 4, imagen 1 de 2 Acer Aspire V3-771G Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: paso 5, imagen 1 de 3 Acer Aspire V3-771G Hard Drive Replacement: paso 5, imagen 2 de 3 Acer Aspire V3-771G Hard Drive Replacement: paso 5, imagen 3 de 3
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
Conclusión
9 personas más completaron esta guía.
David Walker
Miembro Desde 10/11/14
341 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-36, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-36, Donnelly Fall 2014
USFT-DONNELLY-F14S1G36
1 Miembro
1 Guía escrita
Un comentario
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 44
Todo El Tiempo: 13,940
