Saltar al contenido principal
Introducción
The hard drive on a computer is typically used to access laptop applications. Use this guide to replace broken hard drives, which tend to be the most common laptop component to fail. No complicated manipulation is required.
Partes
No se especificaron partes.
  1. To release the battery, slide the orange tab to the right with a spudger. The battery is now released and can be picked up and set to the side.
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Remove the two 5.3 mm Phillips #0 screws. Remove the two 5.3 mm Phillips #0 screws.
    • Remove the two 5.3 mm Phillips #0 screws.
  3. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  4. Pull off the back panel. Pull off the back panel.
    • Pull off the back panel.
  5. Pull the plastic tab on top of the hard drive.
    • Pull the plastic tab on top of the hard drive.
  6. Remove the four 5.3 mm screws that secure the hard drive in the frame. Remove the four 5.3 mm screws that secure the hard drive in the frame.
    • Remove the four 5.3 mm screws that secure the hard drive in the frame.
Conclusión
After replacing the old hard drive, reassemble your device by following these instructions in reverse order.
Una persona más ha completado esta guía.
Maritsa Garcia
Miembro Desde 22/10/18
782 Reputación
5 Guías creadas
Equipo
Baylor, Team S1-G4, Williams Fall 2018 Miembro de Baylor, Team S1-G4, Williams Fall 2018
BU-WILLIAMS-F18S1G4
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 122
