Introducción
This is the keyboard replacement guide for the Acer Aspire TimelineX 4830T-6682. Make sure you have followed all of the prerequisite steps before proceeding!
Qué necesitas
Remove the single screw with a Phillips #0 screwdriver.
Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
Herramienta utilizada en este paso:Tweezers$4.99
Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
Una persona más ha completado esta guía.
