Saltar al contenido principal
Acer Aspire TimelineX 4830T-6682 Back Panel Replacement
Qué necesitas
  1. Acer Aspire TimelineX 4830T-6682 Back Panel Replacement, Lower Back Panel: paso 1, imagen 1 de 3 Acer Aspire TimelineX 4830T-6682 Back Panel Replacement, Lower Back Panel: paso 1, imagen 2 de 3 Acer Aspire TimelineX 4830T-6682 Back Panel Replacement, Lower Back Panel: paso 1, imagen 3 de 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 466
