Introducción
In this guide, you will be able to replace your laptop's RAM with step by step help. The RAM is located on the motherboard.
Qué necesitas
Turn laptop so under side is facing up.
Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
Pry open the cover using the Spudger tool.
Casi Terminas!
Conclusión
