Introducción
This guide will help you locate and replace the Bluetooth.
Qué necesitas
Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
Pry open the cover using the Spudger tool.
Detach the covered wires that connect the motherboard to the Bluetooth.
Remove the Bluetooth module by hand to then replace it.
Casi Terminas!
Conclusión
