Saltar al contenido principal
Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement
Qué necesitas
  1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Battery: paso 1, imagen 1 de 1
    • Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
  2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 2, imagen 1 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 2, imagen 2 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 2, imagen 3 de 3
    • Hold the battery release button, and pull the battery out of the laptop.
  3. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: paso 3, imagen 1 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: paso 3, imagen 2 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: paso 3, imagen 3 de 3
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  4. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 4, imagen 1 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 4, imagen 2 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 4, imagen 3 de 3
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  5. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 5, imagen 1 de 2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  6. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 6, imagen 1 de 2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 6, imagen 2 de 2
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  7. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 7, imagen 1 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 7, imagen 2 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: paso 7, imagen 3 de 3
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  8. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: paso 8, imagen 1 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: paso 8, imagen 2 de 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: paso 8, imagen 3 de 3
    • Detach the covered wires that connect the motherboard to the Bluetooth.
    • Remove the Bluetooth module by hand to then replace it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 34
Todo El Tiempo: 799
