Saltar al contenido principal
Acer Aspire TimelineU M5-581T-6807 Battery Replacement
Qué necesitas
  1. Acer Aspire TimelineU M5-581T-6807 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the screws, indicated by the circles in the picture, from the back panel using the PH1 attachment.
  2. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: paso 2, imagen 1 de 1
    • Note: The back panel cannot be removed. Flip the laptop and remove the keyboard to access the components.
  3. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: paso 3, imagen 1 de 1
    • With the keyboard removed, Locate the battery as seen in the picture. Remove the wire connection above the battery by hand. Grab all the wires and shim the connector out of position.
  4. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: paso 4, imagen 1 de 1
    • Locate and remove the Phillips #1 screw holding the battery in place using the PH1 attachment.
  5. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: paso 5, imagen 1 de 1
    • Pry the battery upwards, using the iFixIt opening tool, to remove it out of the holder.
  6. Acer Aspire TimelineU M5-581T-6807 Battery Replacement: paso 6, imagen 1 de 1
    • Now the battery is exposed and ready for replacement.
Conclusión
6 personas más completaron esta guía.
Edwin VanBaale
Miembro Desde 04/09/19
256 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G1, Hovde Spring 2019 Miembro de IUPUI, Team S1-G1, Hovde Spring 2019
IUPUI-HOVDE-S19S1G1
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 2,233
