Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If your trackpad is not functioning properly or responding, you may need to replace the trackpad. Before attempting to replace the trackpad, please visit the troubleshooting page and follow any recommendations. The troubleshooting page recommends that you update the trackpad drivers and attempt to disable and enable the trackpad to see if it fixes the problem. If the trackpad is still not responding, please follow the steps below to replace the trackpad.
Partes
No se especificaron partes.
  1. Remove the 8, 5.25 mm screws on the back cover using the screwdriver. Insert the opening tool into the USB port. Carefully remove the back cover with the opening tool.
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover with the opening tool.
  2. Lift up on the ZIF connector that secures the ribbon cable using the opening tool. Pull the ribbon cable free. Pull the ribbon cable free.
    • Lift up on the ZIF connector that secures the ribbon cable using the opening tool.
    • Pull the ribbon cable free.
  3. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  4. Remove the 4, 2.5 mm screws from the trackpad cover. Remove the 4, 2.5 mm screws from the trackpad cover. Remove the 4, 2.5 mm screws from the trackpad cover.
    • Remove the 4, 2.5 mm screws from the trackpad cover.
  5. Remove the metal piece that secures the trackpad cover in place using the opening tool. Remove the metal piece that secures the trackpad cover in place using the opening tool.
    • Remove the metal piece that secures the trackpad cover in place using the opening tool.
  6. Remove the trackpad using the opening tool and your hands. Remove the trackpad using the opening tool and your hands. Remove the trackpad using the opening tool and your hands.
    • Remove the trackpad using the opening tool and your hands.
Conclusión
Grecia Corrada
Miembro Desde 19/03/18
1,050 Reputación
6 Guías creadas
Equipo
Baylor, Team S3-G3, Williams Spring 2018 Miembro de Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 236
