Introducción
If your trackpad is not functioning properly or responding, you may need to replace the trackpad. Before attempting to replace the trackpad, please visit the troubleshooting page and follow any recommendations. The troubleshooting page recommends that you update the trackpad drivers and attempt to disable and enable the trackpad to see if it fixes the problem. If the trackpad is still not responding, please follow the steps below to replace the trackpad.
Qué necesitas
Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
Insert the opening tool into the USB port.
Carefully remove the back cover with the opening tool.
