Saltar al contenido principal
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
Qué necesitas
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: paso 1, imagen 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: paso 1, imagen 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: paso 1, imagen 3 de 3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 2, imagen 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 2, imagen 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 2, imagen 3 de 3
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 3, imagen 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 3, imagen 2 de 2
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 4, imagen 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 4, imagen 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 4, imagen 3 de 3
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 5, imagen 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 5, imagen 2 de 2
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 6, imagen 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 6, imagen 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 6, imagen 3 de 3
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 7, imagen 1 de 2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 7, imagen 2 de 2
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 8, imagen 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 8, imagen 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 8, imagen 3 de 3
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 9, imagen 1 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 9, imagen 2 de 3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: paso 9, imagen 3 de 3
    • Pull the docking connector off of the screen section.
Conclusión
2 personas más completaron esta guía.
Grecia Corrada
Miembro Desde 03/19/18
1,134 Reputación
6 Guías creadas
Equipo
Baylor, Team S3-G3, Williams Spring 2018 Miembro de Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 Miembros
6 Guías creadas
Un comentario
Where do you get the docking ports or whatever it is called? With the magnets
Michael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 2,944
