Saltar al contenido principal
Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
Qué necesitas
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: paso 1, imagen 1 de 1
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: paso 2, imagen 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: paso 2, imagen 2 de 2
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: paso 3, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: paso 3, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: paso 3, imagen 3 de 3
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: paso 4, imagen 1 de 1
    • Remove the touchpad.
Conclusión
Max Francois
Miembro Desde 09/28/16
684 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 3-4, Passmore Fall 2016 Miembro de USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Miembros
4 Guías creadas
Un comentario
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 1,569
