Saltar al contenido principal
Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement
Qué necesitas
  1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: paso 1, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: paso 1, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: paso 1, imagen 3 de 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 2, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 2, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 2, imagen 3 de 3
    • There is one zero insertion force connector that needs to be removed.
    • Use your plastic opening tool to flip up the black clip that secures the ribbon cable to the motherboard.
    • Once the clip is flipped up, the ribbon cable will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 3, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 3, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 3, imagen 3 de 3
    • To remove the four bundled cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  4. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 4, imagen 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to gently pull up the speaker closest to the motherboard.
  5. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 5, imagen 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 5, imagen 2 de 2
    • Remove any tape that may be holding down the speakers or wires in place.
  6. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 6, imagen 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 6, imagen 2 de 2
    • Use tweezers to gently pull up the second speaker.
  7. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: paso 7, imagen 1 de 1
    • Remove and replace the speakers.
Conclusión
2 personas más completaron esta guía.
Richard Colon
Miembro Desde 09/28/16
480 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 3-4, Passmore Fall 2016 Miembro de USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 1,353
