Saltar al contenido principal
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
Qué necesitas
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 2, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 2, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 2, imagen 3 de 3
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 3, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 3, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 3, imagen 3 de 3
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 4, imagen 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 4, imagen 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 4, imagen 3 de 3
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 5, imagen 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
Conclusión
9 personas más completaron esta guía.
Max Francois
Miembro Desde 09/28/16
684 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 3-4, Passmore Fall 2016 Miembro de USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 25
Todo El Tiempo: 7,371
