Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If your device can't power on or has trouble retaining charge, you may need a new battery. Use this guide to replace the battery on your device.
Partes
No se especificaron partes.
  1. Wedge your plastic opening tool into the crevice on the volume rocker and pull down like a lever to create space. Slide the plastic opening tool along the crevice to separate the back plate. Slide the plastic opening tool along the crevice to separate the back plate.
    • Wedge your plastic opening tool into the crevice on the volume rocker and pull down like a lever to create space.
    • Slide the plastic opening tool along the crevice to separate the back plate.
  2. Use your screwdriver with the Phillips PH000 attachment to unscrew the single 4mm screw that holds the battery to the base plate.
    • Use your screwdriver with the Phillips PH000 attachment to unscrew the single 4mm screw that holds the battery to the base plate.
  3. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Gently slide the plastic opening tool under the black clip that is attached to the audio ribbon cable. Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • Gently slide the plastic opening tool under the black clip that is attached to the audio ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  5. Remove the tape to expose the left side of the ZIF connector. Remove the tape to expose the left side of the ZIF connector.
    • Remove the tape to expose the left side of the ZIF connector.
  6. Use a plastic opening tool to flip up the black clip on the ZIF connector. Once the black clip is flipped up, it is safe to remove the audio ribbon cable.
    • Use a plastic opening tool to flip up the black clip on the ZIF connector.
    • Once the black clip is flipped up, it is safe to remove the audio ribbon cable.
  7. Use a plastic opening tool to gently push the edge of the sliding bundle cable connector out. The smaller bundle cable connector is the only one that needs to be removed. Remove the battery.
    • Use a plastic opening tool to gently push the edge of the sliding bundle cable connector out.
    • The smaller bundle cable connector is the only one that needs to be removed.
    • Remove the battery.
Conclusión
9 personas más completaron esta guía.
Richard Colon
Miembro Desde 28/09/16
462 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 3-4, Passmore Fall 2016 Miembro de USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Miembros
4 Guías creadas
But one major part is missing from this description!! The battery.
How much is that?
Marcus - Contestar
How can i get a cmos battery off that pc
Kennedy Humphrey - Contestar
How does the Switch 10 back removal process differ from the Switch Alpha 12 back removal process. You don’t have much in the stored “fixes” files for the Switch Alpha 12. Can anything here apply to the “12” too? THANKS
danpobrien - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 44
Ultimos 30 días: 163
Todo El Tiempo: 12,331
