Saltar al contenido principal
Acer Aspire S7-392-6484 Solid State Drive Replacement
Qué necesitas
  1. Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: paso 1, imagen 1 de 2 Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: paso 1, imagen 2 de 2
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Acer Aspire S7-392-6484 Solid State Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire S7-392-6484 Solid State Drive Replacement: paso 2, imagen 2 de 2
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Acer Aspire S7-392-6484 Solid State Drive Replacement, Solid State Drive: paso 3, imagen 1 de 1
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  4. Acer Aspire S7-392-6484 Solid State Drive Replacement: paso 4, imagen 1 de 1
    • Remove the hard drive by pulling it away horizontally from its connection.
Conclusión
3 personas más completaron esta guía.
Nicholas Wise
Miembro Desde 02/14/18
754 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G6, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 2,599
