Saltar al contenido principal
Acer Aspire S7-392-6484 LCD Replacement
Qué necesitas
  1. Acer Aspire S7-392-6484 LCD Replacement, LCD: paso 1, imagen 1 de 2 Acer Aspire S7-392-6484 LCD Replacement, LCD: paso 1, imagen 2 de 2
    • Use a heat gun to heat the edges of the screen, loosening the adhesive underneath.
    • Run a jimmy or similarly thin object around the edge of the screen.
    • Using a suction cup, lift up on the screen to separate it from the adhesive.
    • Be aware that the screen will most likely crack significantly during these steps. Be prepared to immediately replace the LCD should you undertake this repair.
  2. Acer Aspire S7-392-6484 LCD Replacement: paso 2, imagen 1 de 2 Acer Aspire S7-392-6484 LCD Replacement: paso 2, imagen 2 de 2
    • Turn over the display to show the connectors underneath.
    • Disconnect the marked connectors to remove the display from the casing.
Conclusión
Una persona más ha completado esta guía.
Nicholas Wise
Miembro Desde 02/14/18
754 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G6, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,750
