Saltar al contenido principal
Partes
No se especificaron partes.
  1. Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver. Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Unscrew the marked 2mm screws with a Phillips #01 screwdriver. Remove the fan by disconnecting the marked tabs.
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the marked 2mm screw with a Phillips #01 screwdriver.
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  5. Remove the hard drive by pulling it away horizontally from its connection.
    • Remove the hard drive by pulling it away horizontally from its connection.
Conclusión
Nicholas Wise
Miembro Desde 14/02/18
595 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G6, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 8
Últimos 30 Días: 48
Todo El Tiempo: 302
