Saltar al contenido principal
Acer Aspire S3-391-6046 Screen Replacement
Qué necesitas
  1. Acer Aspire S3-391-6046 Screen Replacement, Screen: paso 1, imagen 1 de 3 Acer Aspire S3-391-6046 Screen Replacement, Screen: paso 1, imagen 2 de 3 Acer Aspire S3-391-6046 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Slide the plastic opening tool underneath the frame of your device.
    • Slide the plastic opening tool all around the frame until the entire frame becomes loose and comes off.
  2. Acer Aspire S3-391-6046 Screen Replacement: paso 2, imagen 1 de 3 Acer Aspire S3-391-6046 Screen Replacement: paso 2, imagen 2 de 3 Acer Aspire S3-391-6046 Screen Replacement: paso 2, imagen 3 de 3
    • On the bottom left of the screen there is a black cable with a piece of white tape over it. Remove the white tape by peeling it off.
    • Slide your opening tool underneath the front of the cable, and pull the cable upwards to disconnect it from its socket.
  3. Acer Aspire S3-391-6046 Screen Replacement: paso 3, imagen 1 de 3 Acer Aspire S3-391-6046 Screen Replacement: paso 3, imagen 2 de 3 Acer Aspire S3-391-6046 Screen Replacement: paso 3, imagen 3 de 3
    • Peel the silver tape from the corner of your laptop until it fully comes off.
  4. Acer Aspire S3-391-6046 Screen Replacement: paso 4, imagen 1 de 3 Acer Aspire S3-391-6046 Screen Replacement: paso 4, imagen 2 de 3 Acer Aspire S3-391-6046 Screen Replacement: paso 4, imagen 3 de 3
    • Remove the screen by grabbing the edges of the screen and pulling forward.
Conclusión
6 personas más completaron esta guía.
2 comentarios
Hi! Apparently three films came off with the LCD. Clear,gray and black what are they?
Coolboy_Awesome - Contestar
Thank you. Excellent instructions allowing me to replace LCD ribbon
M Geyer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,692
