Saltar al contenido principal
Acer Aspire S3-391-6046 Keyboard Replacement
Qué necesitas
  1. Acer Aspire S3-391-6046 Keyboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Keyboard Replacement: paso 2, imagen 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Keyboard Replacement: paso 3, imagen 1 de 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Remove the four Phillips #0 screws that are connected to the left and right speakers.
    • Carefully disconnect the wires that connect the speaker to the rest of the computer.
  5. Acer Aspire S3-391-6046 Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove two Phillips #0 screws that are beside the ends of the gray wire.
  6. Acer Aspire S3-391-6046 Keyboard Replacement: paso 6, imagen 1 de 3 Acer Aspire S3-391-6046 Keyboard Replacement: paso 6, imagen 2 de 3 Acer Aspire S3-391-6046 Keyboard Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the gray wire slowly with tweezers.
    • Carefully peel wire off.
  7. Acer Aspire S3-391-6046 Keyboard Replacement: paso 7, imagen 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: paso 7, imagen 2 de 2
    • Slowly remove the two wires that are to the left of the battery with tweezers in an upward pulling motion.
  8. Acer Aspire S3-391-6046 Keyboard Replacement: paso 8, imagen 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: paso 8, imagen 2 de 2
    • Completely remove the battery out of its position.
  9. Acer Aspire S3-391-6046 Keyboard Replacement: paso 9, imagen 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: paso 9, imagen 2 de 2
    • Remove the five Phillips #0 screws that are on the border of the laptop.
    • Disconnect the white wire that is below the fan.
  10. Acer Aspire S3-391-6046 Keyboard Replacement: paso 10, imagen 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: paso 10, imagen 2 de 2
    • Flip all of the circuits upwards.
    • Remove all Phillips #0 screws.
    • Remove the keyboard.
Conclusión
Brian Jimenez
Miembro Desde 09/18/18
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 827
