Saltar al contenido principal
Acer Aspire S3-391-6046 Battery Replacement
Qué necesitas
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: paso 2, imagen 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: paso 3, imagen 1 de 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: paso 5, imagen 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: paso 6, imagen 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: paso 6, imagen 2 de 2
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: paso 7, imagen 1 de 2 Acer Aspire S3-391-6046 Battery Replacement: paso 7, imagen 2 de 2
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 739
