Saltar al contenido principal
Acer Aspire S3 MS2346 Speakers Replacement
Qué necesitas
  1. Acer Aspire S3 MS2346 Speakers Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Aspire S3 MS2346 Speakers Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Aspire S3 MS2346 Speakers Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Speakers Replacement, Speakers: paso 2, imagen 1 de 2 Acer Aspire S3 MS2346 Speakers Replacement, Speakers: paso 2, imagen 2 de 2
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  3. Acer Aspire S3 MS2346 Speakers Replacement: paso 3, imagen 1 de 1
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 551
