Introducción
This guide will walk you through removing the speakers. The speakers may need to be removed if they are damaged, or just to access the components beneath them.
Qué necesitas
Remove the 12 5mm Phillips #00 screws.
Use a plastic opening tool to gently pry open the back panel.
Gently lift up the back panel, exposing the internals of the laptop.
Casi Terminas!
Conclusión
