Saltar al contenido principal
Acer Aspire S3 MS2346 Keyboard Replacement
Qué necesitas
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: paso 2, imagen 1 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: paso 2, imagen 2 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: paso 2, imagen 3 de 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: paso 3, imagen 1 de 2 Acer Aspire S3 MS2346 Keyboard Replacement: paso 3, imagen 2 de 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: paso 4, imagen 1 de 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: paso 5, imagen 1 de 2 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: paso 5, imagen 2 de 2
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: paso 6, imagen 1 de 1
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: paso 7, imagen 1 de 1
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: paso 8, imagen 1 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: paso 8, imagen 2 de 3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: paso 8, imagen 3 de 3
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: paso 9, imagen 1 de 1
    • Gently lift the board exposing the keyboard assembly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,466
