Saltar al contenido principal
Acer Aspire S3 MS2346 Display Assembly Replacement
Qué necesitas
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: paso 2, imagen 1 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: paso 2, imagen 2 de 3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: paso 2, imagen 3 de 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: paso 3, imagen 1 de 2 Acer Aspire S3 MS2346 Display Assembly Replacement: paso 3, imagen 2 de 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: paso 4, imagen 1 de 1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: paso 5, imagen 1 de 2 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: paso 5, imagen 2 de 2
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: paso 6, imagen 1 de 1
    • Unlatch the screen from the frame
Conclusión
3 personas más completaron esta guía.
3 comentarios
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - Contestar
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 3,097
