Saltar al contenido principal
Acer Aspire R7-572-6423 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire R7-572-6423 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Hard Drive Replacement: paso 2, imagen 1 de 3 Acer Aspire R7-572-6423 Hard Drive Replacement: paso 2, imagen 2 de 3 Acer Aspire R7-572-6423 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Remove the top and middle grips that conceal 3 additional screws.
    • Remove the 5 6mm T9 screws.
    • Remove the 8 10mm T9 screws.
  3. Acer Aspire R7-572-6423 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the back cover.
  4. Acer Aspire R7-572-6423 Hard Drive Replacement: paso 4, imagen 1 de 3 Acer Aspire R7-572-6423 Hard Drive Replacement: paso 4, imagen 2 de 3 Acer Aspire R7-572-6423 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Unscrew the four 4mm PH0 screws holding the hard drive in place.
  5. Acer Aspire R7-572-6423 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Tilt the hard drive up and pull it away and out of its base.
    • Do not use too much force on the hard drive or tilt it so much that the base is broken.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 1,392
