Saltar al contenido principal
Acer Aspire R7-371T-72CF Wifi Chip Replacement
Qué necesitas
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: paso 1, imagen 1 de 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: paso 1, imagen 2 de 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 2, imagen 1 de 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 3, imagen 1 de 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 3, imagen 2 de 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 3, imagen 3 de 3
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 4, imagen 1 de 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 4, imagen 2 de 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 4, imagen 3 de 3
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 5, imagen 1 de 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 5, imagen 2 de 2
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: paso 6, imagen 1 de 1
    • Remove the chip by pulling towards the edge of the computer.
Conclusión
2 personas más completaron esta guía.
Dylan Meintser
Miembro Desde 09/27/17
476 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S8-G5, Banghart Fall 2017 Miembro de Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Miembros
5 Guías creadas
Un comentario
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 536
