Saltar al contenido principal
Acer Aspire R7-371T-72CF Power Port Replacement
Qué necesitas
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: paso 1, imagen 1 de 2 Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: paso 1, imagen 2 de 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: paso 2, imagen 1 de 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: paso 3, imagen 1 de 3 Acer Aspire R7-371T-72CF Power Port Replacement: paso 3, imagen 2 de 3 Acer Aspire R7-371T-72CF Power Port Replacement: paso 3, imagen 3 de 3
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: paso 4, imagen 1 de 3 Acer Aspire R7-371T-72CF Power Port Replacement: paso 4, imagen 2 de 3 Acer Aspire R7-371T-72CF Power Port Replacement: paso 4, imagen 3 de 3
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: paso 5, imagen 1 de 1
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
Conclusión
Una persona más ha completado esta guía.
Ethan Frey
Miembro Desde 09/27/17
117 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S8-G5, Banghart Fall 2017 Miembro de Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Miembros
5 Guías creadas
4 comentarios
What’s the part number for the power jack cable, and who sells it?
AcerFan - Contestar
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
Jorge Prado - Contestar
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - Contestar
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 1,690
